Fork me on GitHub
medInria Release Notes
medInria v3.0.0
  • Switch Qt backend to Qt 5.x
  • Switch VTK to version 8.1, including a switch to OpenGL2 backend
  • new, experimental composer workspace to run pipelines
  • Introduce a new plugin framework for the previous purpose
  • A bunch of new image processing algorithms: ITK basic operations (morphology, arithmetic...), bias correction...
  • New data types for diffusion: multi-compartment models (view and estimation)
  • enable image drag and drop on the application
  • scale colormaps option for surface and fibers attributes
  • many more things under the hood !
medInria v2.2.3
  • Fix registration of images encoded in unsigned short
  • Add a colormap for label images
  • Fix rare window-level crash
  • Fix rare thumbnail creation crash
  • New plugin for quantitative MRI T1 and T2 maps estimation
  • Various bugs corrections
medInria v2.2.2
  • Minimum CMake version is now 2.8.10, as it corrects problem with automoc
  • Window/Level sliders are now expressed as Min/Max for easier manipulation
  • Fixed a bug that was wasting disk space by saving non persistent items on disk
  • Restore split presets, ROI file loading, RGB(A) image support
  • Undo/Redo support in paint segmentation
  • Allow coloring of vector field by a single color for field comparisons
  • Fixed Depth-Peeling on NVidia cards, improved general performance a bit
  • Various bugs and crashes corrections
medInria v2.2.1
  • Presets for images are back
  • Reversed Loni Lut added
  • Diffusion workspace bug correction
  • File association on Mac corrected
  • Crashing bug in ITK basic filters solved
medInria v2.2.0
  • Rubber band zoom
  • Add support for VTK vtp file format
  • New application design
  • DICOM import robustness improved
  • Morphological filters (dilate, erode, open, close) added
  • ITK 4.6 and VTK5.10 migration
  • Vector field visualization
  • HighDPI support on OSX
  • New navigator to explore patients/studies/series
  • New view container management system
  • MPR feature added to visualize an image in all orientations
  • Diffusion workspace refactored
  • View and Data Management API updated
  • View properties toolbox improved and a new system to link properties set up
  • Corrections in time line management
  • 2 new registration plugins are added : LCC log-Demons and non linear block-matching registration
  • Many bug corrections
medInria v2.1.2
  • Bug fixes on view/layer synchronisation in the registration workspace
  • Made image annotations more legible on any background by adding text shadows
  • Fixed a crash in medPluginGenerator as well as tests
  • DICOM import fixes
  • Added keyboard shortcuts for orientation buttons
  • Simplified paint segmentation toolbox
  • File browser settings are now saved
  • Mesh thumbnails are now properly rendered on Mac, no more popups on other platforms
medInria v2.1.1
  • Win64 package was using Qt 4.7 instead of 4.8
  • Unix packages were using a dynamic boost, instead of static
  • Temporarily disable mesh thumbnail generation on Mac due to crashes, will be fixed in 2.1.2
medInria v2.1.0
  • First open-source release, code available on github
  • Database edition
  • Undo-redo for registration algorithms
  • New registration algorithm: pyramidal block-matching registration
  • Experimental ODF visualization (for ODF in a spherical harmonics basis)
  • Inter-hemispheric symmetry plane computation
  • Rewritten NL-Means denoising, now includes DWI denoising
  • Improved paint segmentation tool: magic wand, multi-label segmentation, controls simplification
  • View orientation controls moved from right-click to the view properties toolbox
  • Remove, save data, double-click to view data from any workspace using patient navigator
  • Simplified ROI filtering of fiber tracts
  • Direct image file opening from command line, file type association (double click on a file in Finder to view it: Mac only)
  • Screenshot button and shortcut (Ctrl F)
  • "Alt-Tab" like shortcut to switch between workspaces (Ctrl Shift)
  • Many bug corrections and other improvements
medInria v2.0.1-1
  • Fix Dicom plugins load failures on Macos Mountain Lion
medInria v2.0.1
  • Improved UI
  • Added registration algorithms: Baloo, Super Baloo, iLogDemons
  • Registration always performed in float for now
  • Added Segmentation Configuration preview
  • Improved layer aware window level interactions
  • Added INRImage support
medInria v2.0.0
  • Total rewrite of the code from v1.9.0
